KB87820
Published: October 16, 2023
PAC Control: Communication to groov EPIC I/O unit becomes disabled if digital output point is disabled and SET TPO Period/Percent command is used
PAC Control Basic
PAC Control Professional
R10.1a to current (may affect previous versions)
When in PAC Control Debug mode, if you disable a digital output point (channel) configured with the TPO feature on a local groov EPIC I/O unit and then use either the SET TPO PERIOD or SET TPO PERCENT command, communication to the groov EPIC I/O unit becomes disabled.
Re-enable both the digital TPO output point (channel) and the groov EPIC local I/O unit to return to normal operation.
