KB87830
Published:
Revision: 1.1
PAC Control may crash when stepping out of a subroutine
R9.5a through 10.1b
R10.2a
When in PAC Control Debug mode, if you step into (Debug > Step Into) a block and then into a subroutine within that block, if the block has the same name as the subroutine, then when you step out of the subroutine, PAC Control may crash.
Change the name of the block.
