KB87902
Published: June 14, 2019
PAC Control sometimes does not show compile errors dialog for subroutines
PAC Control (Basic and Professional)
10.1b through 10.2a
(may affect older versions)
R10.2b
In PAC Control, when you compile your strategy and there are compile errors in subroutines, the compile errors dialog for subroutines may not appear. Instead, PAC Control looks stuck on the compile operation. The real cause is that PAC Control is waiting for you to acknowledge the compile error dialog, which you can't see because it's not visible.
- If the focus is not on any other application, try pressing ALT-F4 to dismiss the invisible dialog.
- If the subroutine compile errors are related to OptoScript code, then open each OptoScript block and press the Test Compile button.
