KB87904
Published: June 14, 2019
PAC Display Configurator crashes when closing Configure Trigger dialog box
PAC Display Configurator Basic and Pro
All versions prior to R10.2b
R10.2b
When you configure a trigger where the combined length of a tag name and control engine name is greater than 79 characters, PAC Display configurator crashes when you close the trigger configuration dialog box.
If possible, modify the tag name and/or the control engine name in the PAC Control strategy so the combined length is 79 characters or less.
