KB87936
Published: June 14, 2019
EtherNet/IP Configuration file won't open properly when opened from most recently used files list
EtherNet/IP Configurator
All versions prior to R10.2b
R10.2b
In the EtherNet/IP Configurator, when you open a configuration file from from the most recently used files list (File > name of configurator file), the Ethernet IP Configurator does not show the Assemblies.
Open the configuration file with the File > Open menu item.
