KB87937
Published:
OPC server: connection or performance issues
OptoOPCServer
R10.0a through R10.2a
You may see some of the following:
- Client programs such as PAC Display and OptoDataLink can't connect, or the connection fails several times and then succeeds.
- Reduced speed compared to earlier versions of OptoOPCServer
- Inconsistent performance, particularly at startup, such as delays in receiving an initial update
