KB87947
Published: June 14, 2019
OptoDataLink may not transfer data if links contain a large number of tags
OptoDataLink
All versions prior to R10.2b
R10.2b
If you have several links defined, and each link contains a large number of tags (100+), you may see that no data is sent to the output file or database.
Reduce the number of tags in each link.
