KB88002
Published: June 14, 2019
PAC Redundancy Manager may crash when installing firmware on a running system
R10.0a through R10.2a
R10.2b
In PAC Redundancy Manager, if you select "Install Firmware" and select the "Running System" radio button, and if the strategy that is downloaded (as part of the last step of the update) contains variables that are of type Initialize on Download, PAC Redundancy Manager may crash and disappear.
Use version 9.6 of PAC Redundancy Manager.
