KB88055
Published: June 14, 2019
Error number in Description column
PAC Control
PAC Terminal
All versions prior to R10.2b
R10.2b
In PAC Control, when you download and run a strategy, then receive errors, when you look at the Message Queue (either from PAC Control or PAC Terminal), you will see the message number repeated in the Description column, instead of explanatory text or message text.
