KB88057
Published: August 20, 2020
PAC Control auto-discovery configures incorrect default channel type for some analog input modules
PAC Control Basic
PAC Control Professional
R10.2a to R10.3a
R10.3b
In PAC Control, when you choose the option to “Automatically detect and add modules” for groov I/O Units and you select "Automatically create channels within the new modules", PAC Control configures the incorrect default feature/subtype of each channel for the following analog input modules:
  • GRV-IMAI-8
  • GRV-IMA-24
  • GRV-ITMI-8
In PAC Control, do either of the following:
  • When you are adding a new I/O unit, do not select "Automatically create channels within the new modules". Manually add the channels after PAC Control adds the module.
  • If PAC Control already added the channels, manually edit them to set the correct feature/subtype.
