KB88065
Published:
aPAC reports a valid hostname as invalid
All versions prior to 2.01
2.01
When you add a new device and type in a valid hostname, aPAC reports that the hostname is invalid.
Try either of the following when you type in a hostname:
- Enter the IP address instead of the hostname.
- Append the domain name to the host name. For example, <hostname>.your-domain-name.com
