KB88078
Published: April 1, 2020
Gadgets that worked in previous versions may not work in 4.1a and might block access to Build mode
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
4.1a
4.1b
Gadgets using manually configured Opto 22 I/O unit tags will display as if they do not have a tag associated with them, and you can't get into Build mode. The log file will display lines like this:
2019-02-15T10:50:51-08:00 TagDbHandler.getTagById() - Exception occurred while retrieving tag with id 1701 WARN - com.opto22.groov.server.database.TagDbHandler
2019-02-15T10:50:51-08:00 TagDbHandler.getTagById() - Exception occurred while retrieving tag with id 1702 WARN - com.opto22.groov.server.database.TagDbHandler
2019-02-15T10:50:51-08:00 TagDbHandler.getTagById() - Exception occurred while retrieving tag with id 1703 WARN - com.opto22.groov.server.database.TagDbHandler
2019-02-15T10:50:51-08:00 TagDbHandler.getTagById() - Exception occurred while retrieving tag with id 1704 WARN - com.opto22.groov.server.database.TagDbHandler
