KB88092
Published: June 18, 2019
Some PAC Manager Maintenance commands give timeout errors
PAC Manager
All versions prior to R10.2b
R10.2b
If you change the OptoMMP port number on a brain or controller and then try to run any of the following PAC Manager commands (from the I/O Unit Maintenance window), you might get timeout errors:
  • Install Module firmware
  • Install I/O Coprocessor firmware
  • Download File From I/O Unit
  • Upload File To I/O Unit
  • Delete File On I/O Unit
  • Read Filenames On I/O Unit
  • Save Files to Flash
  • Read Files From Flash
  • Clear Flash Files
