KB88123
Published: May 21, 2019
BACNET Server doesn't appear in Add Device dialog in CODESYS
Firmware for GRV-EPIC-PR1
1.3.0 through 1.3.1
1.3.2; also requires Opto 22 Library Package for CODESYS 1.0.0.1 and
CODESYS BACnet SL 1.2.1.0 (available from CODESYS Store)
In CODESYS Development System, when you try to add either a BACnet device or a KNX device (in the Devices view, right-click on the project name and select "Add Device"), the Add Device dialog box is missing the BACnet and KNX devices, even if you purchased and installed the licenses for these products into CODESYS Development System.
