KB88147
Published:
groov View fails to connect to OPC-UA servers
  • GROOV-AT1, GROOV-AT1-SNAP
  • GRV-EPIC-PR1
R2.0a to current
groov View fails to connect to any OPC-UA server if it cannot resolve its own hostname via DNS. Most commonly, after you configure the device and attempt to browse through its tags in the Tag Browser, the tag browser displays:
ERROR: groov may be disconnected
And if you look in the logs, you'll see a line similar to this:
2019-03-14, 09:22:02 GMT-07:00 WARN com.prosysopc.ua.ApplicationIdentity - Cannot determine  Hostname. Using 'localhost'
This issue occurs if groov View cannot resolve its own hostname via DNS.
Make sure that the groov View Server, Box, or EPIC's hostname is in your DNS server and resolves correctly.
