KB88153
Published: May 25, 2021
System update window stops showing progress
Firmware for:
- GRV-EPIC-PR1
- GRV-R7-MM1001-10
GRV-EPIC-PR1: All versions prior to 3.2.0 GRV-R7-MM1001-10: All versions prior to 3.2.0
GRV-EPIC-PR1: 3.2.0GRV-R7-MM1001-10: 3.2.0
In rare cases, when you start a system update, the window that shows the progress of the update may stop showing progress after the "Upload" step. However, the update is still proceeding.
View the logs to determine the current progress of the system update:
- Open another tab or browser window.
- Enter the hostname of your groov EPIC or groov RIO.
- Click Info and Help > Logs.
- Click groov Manage. You will see that lines are still being added to the log. Some lines will have
[INFO] followed by SystemUpdate or Express.
