KB88166
Published: November 15, 2019
Changing the name of a data store tag does not get reflected in View mode
groov View running on:
- GRV-EPIC-PR1
- GROOV-AT1, GROOV-AT1-SNAP
All versions
While in Build mode of groov View, if you change the name of a data store tag and the tag is attached to a gadget, you'll see the following behavior when you switch back to View mode:
- The label name of the gadget does not get updated.
- The name of data store tag does not get changed.
Do either of the following:
- Change the name of the data store device.
- Change the label name to the desired tag name.
