KB88208
Published: November 15, 2019
All strings written to manually configured tags on I/O unit devices are encoded in ASCII
groov View running on:
- GRV-EPIC-PR1
- GROOV-AT1, GROOV-AT1-SNAP
R1.3.0 to current for GRV-EPIC-PR1
R4.1a to current for all others listed
In groov View, if you manually create a tag with a data type of string to an OptoMMP memory map address and you chose a string encoding for your device that is not ASCII, the string won't be written in your chosen encoding. It's written only in ASCII.
