KB88214
Published: November 7, 2019
Controller running strategy with subroutines may reset
Firmware for:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
R9.1a to current
If your PAC Control strategy contains more than one chart that calls a subroutine, and the strategy is run, modified, re-downloaded, and then run again, the controller may reset.
If there is no adverse effect to your application by erasing persistent variable values, then clear controller memory before downloading a new version of the strategy.
