KB88221
Published: May 16, 2019
Stack Full error and groov View flashes yellow triangle on gadgets
groov View running on:
- GRV-EPIC-PR1
- GROOV-AT1, GROOV-AT1-SNAP
R1.3.0 through R1.3.1 for GRV-EPIC-PR1
R4.1a and R4.1b for all others listed
R1.3.2 for GRV-EPIC-PR1
R4.1c for all others listed
You may notice that all the gadgets momentarily show yellow traingles when your groov View project tries to read a numeric table. In some cases, the yellow triangles stay and you'll have to switch to Build mode to recover.
Another symptom is that the controller will return a "Stack Full" error (-62).
