KB88232
Published: May 16, 2019
Inverted scaling of groov analog input not working correctly
Firmware for GRV-EPIC-PR1
All versions prior to 1.3.2
1.3.2
1.3.2
If you configure a groov analog input with inverted scaling (which means the upper scaled value is less than the lower scaled value), the groov EPIC processor reports data incorrectly.
If the groov analog module and your field device support it, you might be able to reverse the positive (+) and negative (-) wires so that the values will be correct without using inverted scaling.
Also see KB88268.
