KB88239
Published: June 5, 2025
Move I/O Unit to Numeric Table command behaves differently with firmware R10.0 and newer
Firmware for:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
R10.0a through R10.5g
R10.5h
If your PAC Control strategy uses the Move I/O Unit to Numeric Table command on a serial B3000 analog address, it treats each analog module as having 4 points instead of 2.  This will affect where the data is placed in the table.
Modify your PAC Control strategy to use the Move I/O to Numeric Table Ex command for serial B3000 analog brains, and specify 2 channels per module.
