KB88259
Published: August 22, 2019
Some conditions always evaluate to true
Firmware for GRV-EPIC-PR1
1.3.2
1.4.0
PAC Control condition blocks containing the following comparisons will incorrectly evaluate as true when comparing an analog input or float variable that contains a NaN value:
  • Equal?
  • Greater Than or Equal?
  • Less Than or Equal?
The condition works correctly for integer variables. NaN means not a number, indicating an invalid float value.
Use the "Float Valid?" instruction before doing the comparison.
