KB88329
Published: May 23, 2023
PAC Control: Should not display the View > Toolbars menu item
- PAC Control Basic
- PAC Control Professional
R9.0a to R10.5a
R10.5b
When you click on the View menu, PAC Control lists Toolbars as a menu item and when you select it, it displays a dialog box. However, the list under the Toolbars field is empty.
PAC Control should not display the Toolbars menu item.
