KB88380
Published: November 19, 2019
Manually configured MMP tags treated as boolean tags during gadget selection
  • GRV-EPIC-PR1
  • GROOV-AT1, GROOV-AT1-SNAP
R1.3.0 to current for GRV-EPIC-PR1
R4.1a to current for all others listed
In groov View, when you do either of the following with a manually configured MMP tag that is assigned any data type other than boolean, the tag is treated as a boolean:
  • Assign the tag to a gadget.
  • Select the tag in the tag palette.
