KB88427
Published: May 25, 2021
Reset I/O to defaults op code (02) does not perform all documented operations
Firmware for:
- GRV-EPIC-PR1
- GRV-R7-MM1001-10
GRV-EPIC-PR1: All versions (see Note below)GRV-R7-MM1001-10: All versions prior to 3.2.0
GRV-EPIC-PR1: 3.2.1GRV-R7-MM1001-10: 3.2.0
In the groov Manage Generic MMP page, when you write the Reset I/O to Defaults OpCode (02) to the Status Write Area (0xFFFF F038 0000) of the memory map, it does not perform all documented options:
- Discrete output channels are not turned off
- Currently running TPOs are not turned off
Note: The GRV-EPIC-PR1 presented a similar issue with the Reset I/O to Defaults feature in
groov Manage (see
KB88247).
To get to the Generic MMP page:
groov EPIC
- From groov Manage Home, click I/O.
- Click I/O Tools.
- Click Generic MMP.
groov RIO
- From groov Manage Home, click I/O Tools.
Turn off all digital outputs (which also cancels TPO).
