KB88434
Published: October 15, 2019
Pulses may not start for groov digital output channels configured for TPO
Firmware for the following modules:
- GRV-OAC-12
- GRV-OACI-12
- GRV-ODCI-12
- GRV-ODCSRC-24
GRV-OAC-12, GRV-OACI-12: R1.0k to 1.3a
GRV-ODCI-12, GRV-ODCSRC-24: R1.0k to 1.3b
1.3b of GRV-OAC-12, GRV-OACI-12
1.3c of GRV-ODCI-12, GRV-ODCSRC-24
If a groov EPIC processor is running a PAC Control strategy and the digital output channels (for the listed modules) are configured for TPO, pulse trains may fail to start in the following situations:
- Changing pulsed operations from an indefinite pulse train (created with the Set TPO Period command followed by the Set TPO Percent command, or the Start Continuous Square Wave command) to finite pulse train (created with the Start On-Pulse, Start Off-Pulse, or the Generate N Pulses command).
Note: To completely resolve this issue, you must also apply updated firmware to GRV-EPIC-PR1 as described in
RM GRV-EPIC-PR1 Firmware Readme. Look for
KB88528.
