KB88471
Published: May 25, 2021
Revision: 4.0
System update may fail immediately
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM2001-10
GRV-EPIC-PR1: 1.4.0 to 3.1.0
GRV-R7-MM1001-10: All versions prior to 3.2.0
GRV-EPIC-PR1: 3.2.0
GRV-R7-MM1001-10: 3.2.0
On rare occasions, a system update may fail immediately and display the error message, Failed to upload system update. This can be caused by a network error or a full disk. If the disk is full then restore to factory defaults and start the update again.
Try one of the following:
  • Power cycle your groov EPIC or groov RIO, then try the update again.
  • If you have physical access to your groov EPIC or groov RIO, try a restore to factory defaults and try the update again:
    1. Insert a paper clip into the Reset hole on the processor and hold it down for eight seconds, until the POWER LED alternates between orange and green; then let go right away.
    2. After the groov EPIC processor or groov RIO module restarts, open up a browser and connect to your groov EPIC or groov RIO module.
    3. Create the first user ID and password.
    4. Click Configure Device.
    5. Click Maintenance > Update > Update System to select the firmware file and start the update again.
