KB88506
Published: September 25, 2019
Unable to save groov Manage > Sparkplug changes
Firmware for GRV-EPIC-PR1
1.4.1
1.4.2
In the Sparkplug configuration page (from the groov Manage Home page, click Sparkplug > Configuration), there is a switch to enable or disable Plain MQTT Protocol. If you enable Plain MQTT Protocol, some fields are hidden because they don't apply.
However, if you enter an invalid value in a field that becomes hidden when you enable Plain MQTT Protocol, then click Save, nothing appears to happen. If you flip the switch again, the hidden field becomes visible again, and then you will see it highlighted in red with a message that the value in the field is invalid.
Disable Plain MQTT Protocol to view hidden fields and either remove or fix invalid values.
