KB88580
Published: November 22, 2019
Momentary button doesn't write Release Value to tag
groov View running on:
- GRV-EPIC-PR1
- GROOV-AT1, GROOV-AT1-SNAP
R1.0.0 to current for GRV-EPIC-PR1
R3.5a to current for all others listed
In groov View, when you release a Momentary button, it writes a value (Release Value) that differs from when it was pressed (Press Value). However, if you navigate away from the current page while holding the button and then releasing it, the Release Value is not written to the tag.
