KB88635
Published: November 22, 2019
Incorrect tag data from multiple Modbus devices
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
R1.3.0 to current for GRV-EPIC-PR1
R4.1a to current for all others listed
If you have the following device configuration, groov View may display tag values for only one of the devices, repeating those values on the other devices:
- A Modbus gateway device with multiple devices behind it, each with a different unit IDs; therefore, the devices share the same IP address and port number.
- Those devices have identical tag configurations.
