KB88664
Published: November 22, 2019
Strings in groov View may contain extra text at the end
groov View running on:
- GRV-EPIC-PR1
- GROOV-AT1, GROOV-AT1-SNAP
R1.3.0 to current for GRV-EPIC-PR1
R4.1a to current for all others listed
After writing a string to an I/O Unit tag, if the newer string is shorter than the previous string, the end of the previous string may still be visible. For example, if the tag starts out with the string "Hello world", and then "BYE" is written to the tag, it will display "BYElo world".
Pad the newer string with spaces to clear out the previous string.
