KB88766
Published: January 31, 2022
Adding a Continue Block without a destination defaults to Block-0
- PAC Control Basic
- PAC Control Professional
All versions prior to 10.4b
10.4b
When you add a Continue block, PAC Control does not require that you specify a destination block. When the strategy is compiled and downloaded, the destination is set to Block Id 0, even though the Continue block shows that no destination block is selected.
When you create a Continue block, always select a destination.
