KB88783
Published: September 23, 2020
groov View Level Indicator in vertical orientation is shorter than before
GRV-EPIC-PR1
GROOV-AR1, GROOV-AR1-BASE, GROOV-AR1-SNAP
GROOV-AT1, GROOV-AT1-SNAP
GROOV-SVR-WIN, GROOV-SVR-WIN-BASE, GROOV-SVR-WIN-SNA
R4.2a and R4.2b
R4.2c
When displayed vertically in the groov View user interface, the Level Indicator is shorter than in prior versions. This issue occurs because the gadget is leaving space for a label at the bottom even when there is no label. The function of the Level Indicator is not affected.
