KB88870
Published: October 5, 2023
PAC Control GetPointerFromName OptoScript command does not compile correctly
PAC Control Basic
PAC Control Professional
All versions
If you use the GetPointerFromName OptoScript command in PAC Control, the block does not compile correctly.
Use the Get Pointer From Name command in an Operation block.
