KB88883
Published: December 23, 2020
Undefined Command Error When Downloading Strategy With Double Quotes in Strings
- PACCONTROLBAS (PAC Control Basic)
- PACCONTROLPRO (PAC Control Professional)
R9.5b to R10.3c
R10.3d
If your PAC Control strategy contains a string that is configured with an initialized value that contains double quotes (“), then when you attempt to download the strategy, the download will fail with an Undefined Command error.
If you want to insert double-quotes into a string, do one of the following:
- If programming with OptoScript, use Character commands. For example:
MyString += Chr(34);
- If using action blocks, use the Append Character to String command.
