KB88935
Published: December 9, 2020
MQTT Topic Identifiers with Spaces are Truncated at First Space Character
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM1001-10
GRV-EPIC-PR1: All versions prior to 3.0.0
GRV-R7-MM1001-10: All versions prior to 3.0.0
GRV-EPIC-PR1: 3.0.0
GRV-R7-MM1001-10: 3.0.0
If you enter a value for any of the following fields (in the MQTT page) that contains a space, the values may be truncated at the first space or misinterpreted:
  • Group ID
  • Node ID
  • Device ID
  • Primary Application Client ID
Substitute spaces with underscores (_).
