KB89055
Published: May 16, 2022
Discrete (digital) input channels may not detect on or off latches
Firmware on the following modules
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDC-24
  • GRV-IDCI-12
  • GRV-IDCIFQ-12
  • GRV-IDCSW-12
All versions prior to 1.3b
1.3b
With discrete (digital) input modules that support on or off latches (listed above), you may observe one of the following behaviors on a channel:
  • Starting from an off state and then clearing the on latch; then turn on the digital input. The on latch may not get set.
  • Starting from an on state and then clearing the off latch; then turn off the digital input. The off latch may not get set.
