KB89097
Published: August 20, 2020
Can't switch between "5-30 VDC" and "Switch Input, Powered" on GRV-R7-MM1001-10 I/O unit
PAC Control Basic
PAC Control Professional
R10.3a to R10.3a
R10.3b
In PAC Control, if you do the following steps, the channel type is not changed:
- Open a strategy with a GRV-R7-MM1001-10 as an I/O unit.
- In the navigation tree, expand the GRV-R7-MM1001-10 branch and double-click Channels.
- In the Configure I/O Channels dialog box, find a channel configured as "DI: 5-30 VDC" or "DI: Switch Input, Powered".
- Click on the Channel Type for that channel and select the other discrete input channel type. For example, if the channel was "DI: 5-30 VDC", then select "DI: Switch Input, Powered".
- Click OK.
- Re-open the Configure I/O Channels dialog box by double-clicking Channels in the navigation tree. You will see that the channel you changed in step 4 has reverted to the previous discrete input channel type.
Change the channel type to something other than "DI: 5-30 VDC" or "DI: Switch Input, Powered", then change it to the desired channel type:
- Open the Configure I/O Channels dialog box.
- Click on the Channel Type for the channel you want to change and select any channel type other than "DI: 5-30 VDC" or "DI: Switch Input, Powered".
- Click OK.
- Re-open the Configure I/O Channels dialog box.
- Click on the Channel Type and select the desired channel type.
