KB89147
Published: February 11, 2021
Subroutine Variable with Same Name and Type as Global Variable May Cause Control Engine Reset
Firmware for:
  • GRV-EPIC-PR1
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
GRV-EPIC-PR1: 1.5.0 to 2.0.2
PAC Controllers: R10.0h to R10.4a
For GRV-EPIC-PR1: 3.0.0
PAC Controllers: R10.4c
In PAC Control Debug mode, you may observe a controller timeout error message (indicating a possible PAC Control engine reset) when stepping through a subroutine in a strategy under the following two conditions:
  • The subroutine contains a local variable with the same name and type as a global variable in the calling strategy.
  • While stepping out of that subroutine, you are inspecting that local variable of the same name.
Do not inspect a subroutine local variable when stepping out of the subroutine if the variable has the same name and type as a global variable in the calling strategy.
