KB89155
Published: December 9, 2020
Files Downloaded from USB are Prepended with Path
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM1001-10
GRV-EPIC-PR1: 2.0.0 to 2.0.2
GRV-R7-MM1001-10: All versions prior to 3.0.0
GRV-EPIC-PR1: 3.0.0
GRV-R7-MM1001-10: 3.0.0
When downloading a file from the USB drive, the filename is prepended with the path. (For example, sdb1_sub1_sub1_file2.txt.) The filename should not be prepended with anything.
Rename the file after downloading it.
