KB89225
Published: October 27, 2020
"Failed To Decompress System Update" Error During Firmware Update
Firmware for GRV-EPIC-PR1
All versions lower than 3.0.0
When you install a firmware update with a file that has "ignition8" in the filename, at the "Decompress update" stage, you see a "Failed to decompress system update" error message and the firmware update stops.
Starting with version 3.0.0, you can identify the Ignition version included in a firmware file by the "ignitionX" component of the filename, where X is the Ignition version. This issue occurs when you upgrade your GRV-EPIC-PR1 firmware from any version lower than 3.0.0 to version 3.0.0 or higher and the firmware file has Ignition 8 or higher. Firmware versions lower than 3.0.0 cannot update directly to firmware versions 3.0.0 or higher that contain Ignition 8 or higher. Instead, do the following 2 steps to install firmware version 3.0.0 or higher with Ignition 8 or higher from firmware versions lower than 3.0.0:
  1. Update to firmware version 3.0.0 or higher containing Ignition 7 (look for "ignition7" in the filename).
  2. Update to firmware version 3.0.0 or higher containing Ignition 8 or higher (look for "ignition8" in the filename).
