KB89227
Published: December 9, 2020
No Historic Queuing When Primary Application ID is Not Set
Firmware for:
- GRV-EPIC-PR1
- GRV-R7-MM1001-10
GRV-EPIC-PR1: 1.5.0 to 2.0.2GRV-R7-MM1001-10: All versions prior to 3.0.0
GRV-EPIC-PR1: 3.0.0GRV-R7-MM1001-10: 3.0.0
If you do not specify a Primary Host ID (from the groov Manage Home page, click MQTT > Configuration, then select MQTT with Sparkplug Payloads as the MQTT Payload), groov EPIC may not save topics into the historic queue. While the instructions indicate that specifying this ID is optional, some MQTT brokers have started requiring that you specify the Primary Host ID.
