KB89245
Published: November 2, 2021
Changes to some OptoMMP public tags do not increment public tags version number
Firmware for GRV-EPIC-PR1
All versions prior to 3.3.0
3.3.0
If values in the following memory map areas change, the OptoMMP public tags version number should increment:
- Analog channel high scale
- Analog channel low scale
- Average filter weight
- Watchdog value
- Enable watchdog
- Steinhart-Hart Coefficient A
- Steinhart-Hart Coefficient B
- Steinhart-Hart Coefficient Second Order Coefficient
- Steinhart-Hart Coefficient C
- Simple Moving Average (SMA)
- Analog channel lower clamp
- Analog channel upper clamp
With this issue, the public tags version number are not incremented.
