KB89389
Published: December 9, 2020
Some Settings Not Saved When Changing Signal Type
Firmware for GRV-R7-MM1001-10
All versions prior to 3.0.0
3.0.0
Some settings may not be saved on the first attempt to change a channel to an analog signal type:
- The first time you change a channel from a digital or analog output to an analog input, the calibration and filtering settings are not saved. For example:
- From the groov Manage Home page, click I/O Channels.
- Click on a channel already configured as an digital or analog output.
- Change the Channel Type to an analog input. Also change any of these fields:
- Gain
- Offset
- Filter Weight
- Simple Moving Average
- Click Save.
- Click on the channel again to return to the channel configuration page. Notice that the calibration or filtering values were not saved.
- Change those fields again.
- Click Save.
- Click on the channel again to return to the channel configuration page. Notice that this time calibration and filtering values were saved.
- The first time you change a channel from a digital or analog input to an analog output, clamping settings are not saved. For example:
- Click on a channel already configured as an digital or analog input.
- Change the Channel Type to an analog output. Also change any of these fields:
- Click Save.
- Click on the channel again to return to the channel configuration page. Notice that the clamping values were not saved.
- Click Save.
- Click on the channel again to return to the channel configuration page. Notice that the clamping values were saved.
Try a second time to change and save the values when you change a channel to an analog signal type.
