KB89408
Published: February 11, 2021
Serial Communication Handle Parameter String With Spaces Prevents Communication
Firmware for:
  • GRV-EPIC-PR1
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
GRV-EPIC-PR1: All versions prior to 3.1.0
PAC Controllers: All versions prior to R10.4c
GRV-EPIC-PR1: 3.1.0
PAC Controllers: R10.4c
In your PAC Control strategy, if you write a serial communication handle with Format 2 (where you specify the parameter string as ser:<keyword>=<value>,<keyword>=<value>,...), the serial communication may not work if there are any spaces in the parameter string. For example:
  • If the communication handle is: baud=19200, data=8, stop = 1, the PAC Control strategy will download and run; however, there won't be any serial communication and you won't receive any indication that it is not working.
  • This communication handle value is correct: ser:baud=19200,data=8,stop=1
Remove all spaces from the serial communication handle parameter string.
