KB89472
Published: May 25, 2021
Revision: 4.0
Numeric tags published too frequently through MQTT
Firmware for:
- GRV-EPIC-PR1
- GRV-R7-MM10001-10
GRV-EPIC-PR1: All versions prior to 3.2.0 GRV-R7-MM1001-10: All versions prior to 3.2.0
GRV-EPIC-PR1: 3.2.0GRV-R7-MM1001-10: 3.2.0
With this issue, publications for numeric tags (from either the PAC Control strategy or I/O) occur more frequently than expected. The publications can be for either string or Sparkplug B payloads.
For I/O tags, set the Deadband setting to a non-zero value:
- Log into your groov EPIC with an ID that has Administrator privileges.
- From the groov Manage Home page, click I/O, then the module, then the channel.
- Click Configure.
- In the Public Access section, click on the Deadband field and change the value to a non-zero value.
- Click Save.
