KB89500
Published: May 25, 2021
Revision: 4.0
No indication when components in backup file fail to restore
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM1001-10
GRV-EPIC-PR1: 2.0.0 to 3.1.0
GRV-R7-MM1001-10: All versions prior to 3.2.0
GRV-EPIC-PR1: 3.2.0
GRV-R7-MM1001-10: 3.2.0
When you are restoring from a backup file, it's possible that the overall restoration process finishes, but one or more components may not have been restored successfully. groov Manage should show you a message indicating which components were not restored successfully and prompt you to reboot. With this issue, groov Manage does not display the message notifying you which components were not restored and the need to reboot.
