KB89503
Published: May 25, 2021
Can't Clear Bit (0-31) Field on Gadget's Properties Panel
groov View running on GRV-EPIC-PR1
3.1.0
3.2.0
In a gadget's Properties panel, if you clear the value in the Bit (0-31) field, groov View turns the field red and prevents you from saving that change.
In the gadget's Properties panel, click on the tag of the Data Source field. In the Update Tag for Gadget window, clear the value in the Bit index (0-31) field, then click Update Gadget. This will clear the value and save the change.
