KB89528
Published: May 25, 2021
Invalid values in firewall rule dialog box appear to be stuck
Firmware for:
  • GRV-EPIC-PR1
  • GRV-R7-MM1001-10
GRV-EPIC-PR1: All versions prior to 3.2.0
GRV-R7-MM1001-10: All versions prior to 3.2.0
GRV-EPIC-PR1: 3.2.0
GRV-R7-MM1001-10: 3.2.0
If you do the following steps, groov Manage continues to show the invalid value after you corrected the value and saved the change:
  1. Create a user rule in the Firewall page (from groov Manage Home, click Security > Firewall > Add Rule)
  2. Enter an invalid value in any of the fields.
  3. Click OK. groov Manage indicates there is an invalid value. You fix the value.
  4. Click OK. groov Manage validates the changes and accepts the valid value.
  5. Click Save.
  6. Click on the user rule you just created.
groov Manage displays the "edit rule" dialog. The invalid value is still shown.  NOTE: groov Manage does save the corrected value; but with this issue, it continues to show the invalid value.
